The job I am on now lists a #3/0 gec ran to the main water pipe. The plumber installed plastic for his main then changed over to copper , are you still required to be within 5ft or can you attach it anywhere with it still being accessible, also concerning wire size is a #3/0 still required or would a #4 be sufficient. I have a ufer ground and 2 ground rods, this is a wood framed building with one steel i-beam supported by several support posts. The posts are not buried in the ground or concrete, set up more like a pole base. The print is calling for a #3/0 for the building steel also but like the water main does this meet the requirements for a gec.
