GerryB
- woodbridge, ct. USA
It's a new house, 400 amp (320 continuous) underground. They are putting a mechanical room in the center of the basement, so I need OC protection, although I thought maybe I could run ridgid or schedule 80 and not need protection but one inspector I know said it's in the house you need protection. Anyone disagree? My other question is I priced out the 400 amp meter socket with manuel bypass (required by this POCO) and two 200 amp breakers and it is about $1500.00. Would it be cheaper to put a 400 amp fused disco or two 200 amp fused discos just inside? The ug meter socket with just the bypass levers is only about $350.00, so there is money to play with.
