Question on article 440.22 (a)
Davidson Electrical
Principle @ Davidson Electrical Services LLC
Tyler, TX
Electrical Contractor
440.22 (a) gives me the impression that we aren't supposed to use 225% to size the overcurrent protection device unless 175% is not sufficient for the starting current. However, in Mike holts 2014 electrical exam prep book all of the protection sizing calculation examples for motor compressors use 225%.. so what am I missing?? I know I can use the nameplate most of the time and I Probably won't see this on my upcoming test but I would really like to know thanks!!
Smart $
Esteemed Member
Ohio
Welcome. :thumbsup:
If the question asks for the maximum overcurrent protection rating, using 225% is correct.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Smart-- go to sleep---:lol:
Seriously, when a question came up a long time ago you stated we should always use the rule not the exception when answering a question. Is this not the same?
Smart $
Esteemed Member
Ohio
:sleep:
:sleep:
:sleep:
:huh:
In this case, 225% isn't written as an exception to that section. It is actually stated right in the section. Test question authors will likely consider that fair game. :D
Davidson Electrical
Tyler, TX
Found it
Found it
Found some other calculations in the same book using 1.75 and 2.25 if that doesn't work.. so guess that is right. Those examples just confused me..
kwired
Electron manager
NE Nebraska
Poor question as worded I would say. Without "maximum" being in the wording anything under 226% is an acceptable level code wise.
