question on driven ground rods
sparkyjr55
louisville, ky
Can anybody tell me if i made a boo boo? As about 2 years ago i drove 2 ground rods for a home elec service and ran from the elec panel a #6 thhn to one ground rod and a #6 thhn to the other ground rod from the elec panel as the plumber was replacing the copper pipes in pex. The elec inspector was looking around at what i did and passed it but said up in the east end of the city the electricians up there would run a #6 thhn to one driven ground rod and then from that ground rod a #6 to the other ground rod.
Did i do anything that was wrong?
You did fine. You don't need to run thhn thus a bare copper wire would be okay. Normally I run one bare #6 and loop from one rod to the other with no splice but your way is code compliant also.
wasted a few feet of copper wire
As you can see, no, but you did waste a bit of labor and materials.
Just for info, only the wire to the first rod need be unspliced. A separate piece (with separate clamp) could be used to jumper to the second rod.
This I know but then you have to use another clamp. I like the idea of a continuous piece-- one less thing that can go bad.
Strangely enough, I recall a few guys talking about inspectors red tagging them for running one EGC from the panel to each rod. This was years ago (before my company). I believe the argument was: it wasn't a continuous run. Something of that sort. My mind isn't clear on the issue, because it was so long ago.
As long as each one is continuous, it's compliant. I once ran an unbroken GEC from rod to disco to disco to rod.
The inspector took about 10 minutes to decide it was okay: each disco saw two rods.
that was not clearly defined until the 2008 NEC. Just keep in mind it is the GEC and not the EGC we are talking about.
