Scheffler Energy
- Minnesota USA
- Master Electrician
Hello!
I have a couple general questions I am still learning as a new business owner!
1# when replacing a 3 wire dryer outlet to a 4 prong do you have to run a new wire if there is no ground
2# do you have to update the breaker to GFCI protected when replacing a outlet
3# does a garage electric hanging heater need a disconnect with in sight or so many feet of the heater ?
Thanks you !
Code 2023
Thanks you !
Code 2023
