Question on flexible metal conduit
ENH
Tennessee
I recently took a test that had the following question and I could not find the answer for it. "What is the minimum bending radius for 1/2 flex where the final connection requires flexibility?" I checked Article 348 and Table 2, Chapter 9 "other" but could not seem to find the answer. Can anybody point me in the right direction on how to calculate this or find this answer? Thanks
Thank you for your response but the test was multiple choice and 4" was not one of the answers to choose from.
Was the question about flexible metallic conduit or flexible metallic tubing. For FMT the answer is 12½". {T360.24(A)}
Hmm. I thought I remember flexible metal conduit but maybe I could have misread the question. I see the article you are referencing and its pretty clear about the minimum bending radius. Thanks for your help!
The two are very easily confused so if it were really about FMT that would explain why the correct answer for FMC wasn't there.
I have never used FMT and don't think I have ever seen it on a job. However, it is required in plenum ceiling by the Chicago Electrical Code.
The only time I've even seen it was on recessed high hat style light fixtures that were approved for use in Chicago. They were required for our application so I'm guessing someone ordered the wrong part number.
