Question on grounding a radio tower
Methu969
New member
Vail, AZ
Hello,
I am a Ham Radio operator and I am constructing my first tower. I am looking for information on the proper way to ground the tower. The tower will be 40ish feet tall and in a concrete base.
The tower is secured at the second section to the roof fascia.
I am reading to install 3 grounding rods around the tower and connect each rod to a leg of the tower and them connect all three rods with a #6 copper wire around the tower base. The tower will be 20' from the house electrical panel and that ground rod.
Do I need to connect the 3 tower ground rods to the house grounding rod?
I am closing this thread in accordance with forum rules. If you are not employed in the electrical industry in some way, then we are not permitted to assist you with electrical design or installation work.
