Hi all,
I have watched Mike's video on fundamentals of grounding and was confused in few areas.
He was talking about bigger equipment like CNC machines or generators will not need a ground rod to protect them from lightning, and lightning can actually cause potential difference at the ground rod, which can make lightning pass through the machine and ruin the machine electronics. This is understandable.
But won't indirect lighting cause pressure on electrons in metallic parts of these kind of bigger equipment? Won't this create over voltage in these bigger machines? Then won't we need 'metal' equipment grounding in this case?
Also he was teaching about equipment grounding and we provide grounding to metal part of equipment to reduce over voltage induced due to lightning or any other over voltage sources. But, in this case won't the indirect lightning cause potential difference at the ground rod? And won't this lead lightning to pass through the metal parts of the equipment? How is grounding helping to make the equipment safe in this case?
Please help when you get a chance.
Thank you for your time.
