Question on LED fixtures
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
Since there are no lamp sockets or bases involved can I wire them to a 30 amp circuit and be legal?
I don't have the instructions for the fixture so I'm not sure if it will tell me what I can do as far as wiring to circuit size.
What info I have found does not give and wiring instructions.
Here is the model: LBL4 LP840 Lithonia
P.S. It's not me that wants to do this, it is our customer......
Well, the fixture wire, if used, would be like a tap conductor that probably relies on a maximum size upstream OCPD. The information on that may be buried in the UL approval standard that the fixture is tested to.
Problem solved. Told customer we weren't going to fuse a ckt. at 30 amps that would never draw more than 5 amps.
