Question on load shedding breakers???
jango
When it comes to load shedding and using load shedding breakers, is it just a matter of changing out existing standard circuit breakers and replacing them with load shedding breakers? Or is it a completely different system? Any insight on this and/or direction would be greatly appreciated.
There is no single method. It can be as simple as using a sub-panel and only switching those loads automatically, or as complicated as adding LV-control-voltage interruption to HVAC equipment.
What type of load shedding breaker are you asking about?
A simple shunt trip breaker that once tripped need manual resetting or a controlled breaker like a Square D Power link that can be remotely turned on or off as needed?
What are my options for either one?
