Question on voltage drop
daryl
I have a buddy who needs a 20 amp GFCI about 300 feet outside from his house to power A pond waterfall and low volt lights. He needs all 20 amps. Actually only about 14 but the start up amps for the pump are like 20 amps. Anyway I heard that every 100 feet we should up the wire size, to accomodate voltage drop. I can't find it in the code book. Do I have to run #6 wire out there. Please help Thank You
Re: Question on voltage drop
Using 20 amps, #6 at 300 ft will give you (rounded up) 115 volts, so I'd say yes you need at a minimum #6.
Roger
[ April 20, 2005, 08:48 PM: Message edited by: roger ]
so bring the #6 through the pvc, into the box, and then wire nut #10 to it to put into the back of my GFCI? I know it would work but sounds weird, and would look weird what do u think?
[ April 20, 2005, 08:56 PM: Message edited by: daryl ]
Daryl, I'd reduce to a #12 in the device box (oversized box if possible) and the panel.
Roger
Sorry if I sound stupid but I should wire nut it in the panel too huh? #6 won't fit in a 20 amp breaker? I've actually never tried it, so I don't know if it would or not. I believe I have to up my ground to don't I?
Daryl, yes you will most likely need to wire nut a #12 to the #6 in the panel to fit into the breaker.
You are correct that you will need to increase your EGC proportionately, see 250.122(B) 2002 NEC.
Roger
If the motor draws 14 amps at 115 volts, and it can be connected for 230 volts, the current will decrease to 7 amps. The single-phase voltge drop for 14A @ 120V is 3.4 percent or 4.125 Volts for NO. 6 copper conductors. For 7A @ 230V, No. 10 copper will give a VD of 2.25 percent or 5.2 Volts.
hi i get a different number
i am assuming single phase, 115v, copper wire
i use vd=2xkxIxd/cm
d/cm=300/52620cm (#3) =.00570
k=12.9 for copper
I=20amps load
vd=2x12.9x20x.00570 and i get 2.94 percent
that is under 3 percent so number 3's
Guys, If I'm reading this correct he said it was 300 feet away. Remember that you must add the return also on this distance. So 300' x 2= 600' we need to figure for voltage drop.#4 uncoated copper at this distance would give you a 3.7 voltage drop if I did my math correct for a 20 amp load. A #6 at this distance at a 14 amp load would be a 4.124 voltage drop. I believe I did my math right.
Jim
I just checked Roger's first post (out of curiousity) and it's accurate.
I may have converted it to different terms, but it's still correct.
I hav'nt looked at any other posts.
I will store it next to zinsco and fed pacifics.To me they are about the same.Do others find they change out far more GE than square d or other top brands ?
Jim, are you posting in the right thread? :roll:
Roger
Hello Sam, of course my post was accurate. :D
Roger
