JJWalecka
- New England
I have a question regarding the isolation of low voltage, 120/208 and 277/480.
A 12 x 12 trough has various EMT's installed into it. The trough has 3" nipples installed to various panels. A few 3/4 Emts installed on the same unistrut and installed into the same trough is use for low voltage cable. The Belden cable is installed in the raceway to roof top units. Inside the trough the EMT is changed to Greenfield by rigid coupling. The Greenfield is sleeved through the same nipple as the Branch circuits for the roof top units. The Greenfield is taped on the inside and outside for anti short purposes.
It is my understanding that a isolation barrier should be installed between This low voltage cable and the 277/480.
Would Greenfield used in the application be considered an approved barrier?
The low voltage would not have a barrier in the panel.
Any opinions would be appreciated.
Justin W.
Justin W.
