JFletcher
- Williamsburg, VA
What article(s) of the NEC cover powered furniture, like tables and tool boxes with power strips/built-in receptacles?
That's the way I see it. Other's opinions differ and so do some code sections.once you plug into an outlet, you're on your own.
In my opinion they are not covered by the NEC they are utilization equipment.
605.5 Lighting Accessories. Lighting equipment listed and identified for use with wired partitions shall comply with 605.5(A), (B), and (C).
(A) Support. A means for secure attachment or support shall be provided.
(B) Connection. Where cord-and-plug connection is pro-vided, the cord length shall be suitable for the intended application but shall not exceed 2.7 m (9 ft) in length. The cord shall not be smaller than 18 AWG, shall contain an equipment grounding conductor, and shall be of the hard usage type. Connection by other means shall be identified as suitable for the condition of use.
Lets assume for a moment a fixed conference table. Bolted to the floor, if you will. Hard wired. Electrical comes out of slab and services desk receptacles. Is hard-wiring something like this a violation, or is there an article that covers this desk? Not part of the building, but fixed in place.
