hhsting
- Glen bunie, md, us
- Junior plan reviewer
I have meeting room greater than 1000 square feet. Would NEC 2017 Article 210.71(B) apply to this meeting room?
No.I have meeting room greater than 1000 square feet. Would NEC 2017 Article 210.71(B) apply to this meeting room?
I read that as the rooms 1000 sq.ft or less need the locking receptacles, I assume for projectors. Rooms larger , I assume are designed for projectors from above so they would not need that locking receptacle. I am sure I am wrong.
David disagrees with me.Yes and then no? Dont follow
The requirement for meeting rooms 1000sf or less is for non-locking receptacles, not locking receptacles.I read that as the rooms 1000 sq.ft or less need the locking receptacles, I assume for projectors. Rooms larger , I assume are designed for projectors from above so they would not need that locking receptacle. I am sure I am wrong.
This begs the question is there no req. for meeting rooms >1000 sq.ft
I am with David as soon as the meeting room is greater than 1000 SQFT the section does not apply.appears to be tie yes and no. How can one break this tie?. What does it mean?
If you have a meeting room that has more than 1000 square feet, you can stop reading. Just like most other area in non-dwelling occupancies, there is no receptacle requirement for a meeting room larger than 1000 square feet.(A) General.
Each meeting room of not more than 93 m2 (1000 ft2) in other than dwelling units shall have outlets for nonlocking-type, 125-volt, 15- or 20-ampere receptacles. ....
You question has been answered a number of times. I was incorrect in my assessment. How can 210.71(B) apply -- Don stated no requirements for meeting rooms larger than 1000 sq.ftOk but what about 210.71(B) and meeting room larger than 1000 sq? Does it apply?
