troubleshooter
I don't know if anyone out there has ever had a similar situation but I do a lot of electrical troubleshooting and I got a call the other day. A man claimed that his daughter had been shocked in the shower. The house is a historical landmark. An old bed and breakfast, not in uise as such anymore but a beautiful house. He explained that his daughter had been in the shower and reached down to adjust the temperature and when she touched the faucet she got shocked. I opened the tub access door and pulled out my fluke pen tester and right off the bat it lit up. I went to get my meter and acroos the hot and cold water line I got nothing, but from the hot water to the drain I got 78 volts? The same with the cold water line. I looked under the (metal) tub and saw an old BX line that was run underneath of the tub which was sitting on shims years ago that have since deteriorated sot the tub is now smashing the wire. When I shut the circuit off to the BX wire there is no voltage on the water lines. I cut the BX and installed juntion boxes so the wire was no longer under the tub. The water pipes are still live? So I check the rest of this huge house and every faucet in the place is live? The gas lines have voltage present. I have been wiring a new circuit to take the BX circuits place, but I'd really like to know if anyone has ever seen this before? Especially since it's not just one pipe but the gas line also? I checked the ground coming from the panel to the water pipe and there isn't voltage present there. Can anyone offer any advise?
