After reading about separately grounded phone lines being a bad thing, I took a look at mine. The line comes in on the opposite side of the house from the service, and was grounded to its own ground rod. In an attempt to equalize the potential, I ran a ground wire to the nearest outdoor faucet, (which I tested for continuity to the system ground). Is this allowable?
Should I have disconnected the ground rod and gone straight from the phone box ground wire to the faucet?
Or am I required to go all the way around the house to the service panel (and disconnect from the phone line ground rod)?
David
David
