M4gery
Today I did some work in a really old house, half of the walls are open and half are closed so I have to mixed and match old and new wiring and box things where necessary.
In the bathroom I had a feed coming into a switchbox, a 3-wire coming out of the switchbox into a light, then a 2 wire coming out of the light and going off to another receptacle down the line. So the 3-wire coming out of the switch has a neutral, hot, and switched hot. This is really old BX with that cloth type covering on the wire that breaks away easily, unfortunately I had to re-use that 3-wire coming up from the switch, this is where I ran into trouble.
I wanted to see if I could identify those 3 wires using a continuity tester, I didn't want to open the switch box and possibly damage those wires (just by moving them). The first thing I did was try to read continuity (with my Fluke 322) from a known grounded source to 1 of the 3 wires- None of them rang out. I figured the neutral would show continuity since it's bonded to ground in the panel. I measured 120V from hot to this same grounding point so I should have been able to read continuity from a neutral wire to this point, right?
Second, I tried to read continuity thru 2 out of the 3 wires while the switch was in the on position, this should go off when the switch is off. Unfortunately I couldn't read continuity thru any sequence of the 3 wires. IMO it should have rang out between the hot wire and the switched hot wire when the switch was turned on.
Neither of these methods worked and I am wondering why...?
I ended up opening the switch box and identifying the wires that way, everything worked when I was done, but I am still stumped on why I wasn't able to get it to work with a continuity tester...
