GerryB
- woodbridge, ct. USA
Two questions. The last few years or more I thought you could no longer install a gfi in the tub base itself, even with the acess door, and that a disconnect switch was required in the bathroom 5 feet away. So typically a dead front gfi was installed above the other bath switches and a duplex in the tub enclosure. I do not see that .
The other question is for example 2nd floor massage tub, all plastic plumbing, is the #8 ground required and where would it go?
