Do You Like Ham
- TX, USA
In a typical 208v to 120v isolation transformer installation, where the 208v is comming from a 3-phase service, is the 120v secondary still 120 deg out of phase line-to-line?
As I understand it (trying to digest http://stevenengineering.com/tech_support/PDFs/45HIPS.pdf), there is no neutral (e.g., where the two conductors on the 120v secondary connect to a receptacle), these are actually two hot/line conductors... which is why they have special color coding (page 8) is that right?
I'm trying to digest the calculations in http://www.pglifelink.com/pdf/isolated-power-explanation.pdf
On page 3 after diagram 6, the value 1201000 is in the denominator... where did this number come from?
Related post I found: http://forums.mikeholt.com/showthread.php?t=51993
In that 277 to 120 case, it says "59.5 Volts on a "phase"", I'm curious what was meant by that. What would be the voltage on a "phase" be in my 208 to 120 case? Is it 69.3 (120 / sqrt(3))? My first reaction would have been that the voltage would have been indeterminate since it is isolated (thus, nearly infinite impedence?)
Thanks, much... I've never worked with one of these scenarios before.
