Yes You will need 4 wires from your main to your sub panel. Two hots, neutral, grounding conductor. Establish a GES at the sub panel & separate your grounds & neutrals in this panel. If you ran Rigid or IMC, or EMT between panels the conduit could serve as the grounding conductor. Others will chime in.
