Hi! I am hopeful that someone will be able to direct me to the proper code section for the following question:
"Input leads to a transformer supplied from a power-supply conductor supplying a class 2 or 3 circuit, #18 type ZF shall be protected by an overcurrent device rated not over 20 amps if the conductor length does not exceed:...."
Thank you in advance.
