No way. 200 amp SER at $1.79 a foot.celtic said:How about somehting NOT obsolete...pricing accuarte?
So... is this program a secret? or, are you willing to share its name?celtic said:I already have a FREE program...that updates(free) whenever I decide to allow it...integrates w/QuickBooks....I'll pass on this.
mdshunk said:So... is this program a secret? or, are you willing to share its name?
You can...but at about 30.45/hr ...is that the right number for you?electricguy said:2 questions
can I change the labor rate in the HD disc
Start the program....electricguy said:How do I change the labor rate in TNE
If the hourly wage you see in the Enter Cost Information dialog box is not right for your job, change it. Home Depot PRO CD lets you enter or change hourly wages every time you:
? Paste lines from the costbook.
? Insert cost lines of your own.
? Change a cost line in the estimate.
To change the hourly wage in the Enter Cost Information dialog box:
1. Press Tab to advance to the hourly wage box (or click on that box).
2. Type the hourly wage you prefer.
3. Press Tab to advance the focus.
4. Notice that the new hourly wage times the hours produces a new labor cost.
5. Click on OK or press Enter when done.
6. The cost line is added to your estimate at the hourly wage you typed.
Tips on changing wage rates:
? Changing the hourly wage for any crew affects only the estimate you are working on. It does not change anything in the costbook or in other estimates.
? You can change the hourly wage for any crew and even make up your own crews and hourly wages.
? Crew codes have to be two digits. But all numbers and letters work fine.
? You have to change the rate for any crew just once. Home Depot PRO CD will apply that rate automatically every time you paste or insert more cost lines using that crew.
? Home Depot PRO CD will display both the wage rate being used and the costbook wage in the Enter Cost Information dialog box.
Can I "globally" change the labor rates in the costbook(s)? Not in the costbook. However, it's easy to adjust labor rates in an estimate. Any time you copy and paste costs into an estimate, you see the labor rate. Change that rate once and it's changed throughout the estimate. But making that change doesn't affect the costbook and it doesn't change any other estimate you've already completed. For more on setting your own wage rates, press F1. Click on Search. Type Wage and double click on Custom.
electricguy said:.. my overhead was running around 4000/mo AND I work from my home.
I had to read that twice...I thought you were quoting me but forgot the quote[]'s LOL.electricguy said:You can...but at about 30.45/hr ...is that the right number for you?
Why mine shows as 30.45 and not 29.85 (this is for L1), I don't know? I don't really care as I automatically change that rate on every bid."Crew Code" "Crew" "Hourly Wage"
"B1 Carpenter and a helper 25.29"
"B9 Bricklayer, Tender 25.68"
"BC Carpenter 27.93"
"BF Floor layer 26.93"
"BG Glazier 26.06"
"BL Building laborer 22.66"
"BR Lather 27.66"
"DI Drywall installer 27.38"
"L1 Electrician 29.85"
"P1 Plumber and a helper 27.07"
"RI Reinforcing ironworker 26.09"
"RR Roofer 34.41"
"R1 Roofer and a helper 27.03"
"SW Sheet metal worker 30.90"
"TL Tile layer 26.96"
HD doesn't offer these two areas."How to Use This Book 5"
"Improving Estimating Accuracy and Profits 7"
