bori
- Miami, Florida U.S.A.
Just out of curiosity, does anyone know if the quick connect splices that come inside some fixtures have to be used by code? I looked in the NEC and found nothing about this. I was told by a Master Electrician that such requirement is in place to protect Maintenance Personnel when replacing a Ballast. Read 410.130 (E) General and (G) Disconnecting Means..110.14 Electrical connections. The Quick connect prevents physical contact between dissimilar metals (110.14), does it fall under 410.130 (G) (I), as disconnecting means?. Thank You.
:dunce:
:dunce:
