- Lockport, IL
- Semi-Retired Electrical Engineer
We are replacing a group of sump pumps that remove water from a drainage sump at a dam. Each pump can be hauled up (about 25 feet) by a chain connected to a bail. The power cord and signal cable are loosely attached to the chain, so they ride up when the motor is lifted. The current practice of the maintenance crew is to cut the cables and splice the new cables that come with the replacement pump. I would like to know if I can simplify this task by calling upon the motor manufacturer to include some type of quick disconnect for the power cord and the signal cord.
One of the replacement pumps is 100 HP and will have a three phase 2/0 power cord. Another pump is 40 HP and will have a three phase #4 power cord. Each pump will have temperature and vibration sensors. I am anticipating a 6 or 8 conductor #14 signal cable. Are there quick disconnects that can work with these cords?
