I’m installing this piling light on a saltwater dock with composite pilings and using marine-grade 12/2 tinned copper wire. I’m running conduit up through the piling with a junction box at the base. Since this fixture is solid bronze, is it internally bonded to ground, or do I need to run a separate bonding jumper to the mounting screws? Also, do you recommend sealing the fixture base with dielectric grease or just relying on the gasket for corrosion protection in a tidal zone?
