nesc.org National Executive Service CorpsOriginally posted by Thom Peterson:
Cable system at the utility pole line is covered under NESC.
You're describing a ground block (a term I recently learned)? There isn't a ground where it enters the building.Originally posted by dereckbc:
For CATV it is usually a surge arrestor mounted on a building where the service lateral enters. It looks like a coax splice with a ground screw. It is from this point where the CATV needs to be grounded to the electric service electrode as covered by NEC 820.40
You are correct, it is called the ground block. However, that is the point where the CATV is grounded before entering the building. It is a requirement of NEC 820.40. It is to protect the building or house incase the CATV comes into contact with high voltage lines or discharge lightning strikes.You're describing a ground block (a term I recently learned)? There isn't a ground where it enters the building.
The same thing that would happen if the splitter were not there. The splitter is attached to another splitter right above it which is bonded to the grounded messenger. The splitter's enclosure case in question is electrically the same as the coax shield. To add a short ground wire from the splitter enclosure case to the splitter above it would serve no purpose from a safety or technical view point. The shield of the CATV line is bonded to the pole grounds along the way.You say it would serve no purpose to ground that splitter, but what would happen to the cable plant if, during a storm, a tree limb dropped and brought a powerline down on it?
If a power line were to fall on the CATV line and and by some chance make electrical contact, the voltage would travel in all directions.
I'm making an assumption here, and please correct me if I'm wrong: the purpose of these electrical codes is to protect us in these unlikely situations.Originally posted by dereckbc:
It is highly unlikely the utility line would make contact with the coax, but if it did the provisions are there to take care of it.
You seem to be making an assumption that things are generally done properly. I'm trying to convince myself you're right, but I'm having trouble.Originally posted by dereckbc:
Besides, I think you are overlooking that the CATV coax is mounted on the messenger wire. The messenger wire is grounded to every pole attachment.
I can't tell whether the violations are at the building, or at the plant, or some of each. Can you?Inspection Report:
The County continuously inspects the quality of the in-progress construction work and the resultant physical cable plant and equipment in the public rights-of-way. These inspections verify the extent to which the construction complies with the engineering design, construction standards for physical cable plant, installation of equipment on the cables, safety of work-in- progress, and the restoration of work areas after construction is completed.
(snip)
After construction is complete, the physical plant and construction work areas are inspected to verify that construction and restoration of the work site complies with the standards required by the Franchise Agreement.
(snip)
The number of ?Construction? category violations for the first quarter accounts for nearly 60% of the total violations, slightly less than last quarter. Approximately 25% of the construction category violations are grounding related; half of those for no grounds where required. The other grounding problems found involved ground rods protruding too high out of the ground or above the pedestal base. There were many sites where there were ground rods and wires installed but the wires were simply not attached to the ground rods, which is effectively the same as no ground at all.
It's not that I don't believe you... but I want to see this with my own eyes. I've never heard those terms before, and I'm scared to do a google search on "balls" and "butts"!!!Originally posted by al hildenbrand:
In the picture you have posted, the aerial messanger will be bonded to ground balls or pole butt plates.
