if the load calculation for the house is 151 amps should I use a 150 amp breaker or a 200 amps breaker?
I have a main disconect (200 amps), from there I need to feed a panel(house circuits) in the garage , the wires used are 2/o , from the meter to the main disconect and from the main disconect to the garage panel. there is currently a 150 amp breaker for the garage panel , but the load calculation is 151.3 I believe , can I just replace the 150 amp breaker for a 200 amp breaker? .Then from the main disconect there is another feeder for a sub panel a 100 amp breaker , this is confusing to me. if the main disconect is 200 amps then how can I have a 150 amp breaker and a 100 amp breaker in it?
thank you very much for any help.
