I am a New York State electrical contractor in Westchester County. I recently installed four outdoor fixtures above four store fronts, one for each store. The fixtures were supplied by the owner. The job consisted of drilling through brick on front facade, snaking wire to inside store ceilings, which were closed sheet rocked ceilings above drop ceilings. I had to make a hole in the second closed ceiling big enough to peek in to see snake, pull wire, snake down wall to install and cut in a switch for the light. Each store was occupied so work had to be done cautiously and neatly during business hours. Three stores required a run of 25 feet of 12-2 BX and boxes, one required a further run of 75 feet and to pick up a feed in basement, and snake in wall to switch location. Fixtures required to be drilled and raw plugged for mounting, total hours 12, a day and a half, one man I charged $1600, $400 per store, was I too expensive??????????
