Quotes in messages
mkgrady
Massachusetts
I like the way some of the posters address others questions or comments by quoting the other person and then answering the quoted material. Then they will continue to do this until all the relevant quotes are addressed. Can someone tell me how to do this. I can't find anything in the FAQ area.
Re: Quotes in messages
First you click this
above the post you want to post.
If that is all you do the entire post will be quoted.
You will also see the UBB code that makes the quotes appear.
The code at the beginning of the quote looks like this
[QB]
At the end of the quote
[QB]
I had to leave out forward slashes in order for you to see it.
You can use cut and paste techniques to remove what you want and break i up into multiple quotes.
Now that you know, a request: choose the most relevant of what the other member said, to quote. If you can't single out a sentence or two, or if you have an issue with the post in it entirety, just address your post to that member.
As in,
Bob, I disagree with your entire post. Did you get your license out of a crackerjack box?
Instead of:
First you click this above the post you want to post.
[QUOTE)Originally posted by mkgrady:
[QB)
[QB)[QUOTE) I had to leave out forward slashes in order for you to see it.
Did you get your license out of a crackerjack box? Quote me on that!
It gets real old seeing someone's entire post quoted. It defeats the purpose, IMO. :)
Originally posted by georgestolz:
[QB] Now that you know, a request: choose the most relevant of what the other member said, to quote. If you can't single out a sentence or two, or if you have an issue with the post in it entirety, just address your post to that member.
Thanks George and Bob. Now I'll see if it worked
It looks like you cut off the UBB Code at the end of the post.
Hit the edit button
above your post and add this to the end of what you want to quote.
[/QB][/QUOTE]
[ January 28, 2006, 12:47 PM: Message edited by: iwire ]
You forgot the
That tells the website where the end of the quote is. :) [/QB][/QUOTE]
OK, I see that now. So even if I cut out the bottom half of a quote I should leave the [/QB][/QUOTE]in place where I end their quote.
You can always click "edit" on any post to see the command codes for any special features. You can't edit other peoples posts, but you can look at how they did what they did.
Don
Another strong tool is the "preview post" button next to the "add reply" button under the message screen. On the post above where I "quoted" Bob quoting you, I had to fix it four times before I posted it, because I built it from scratch, copying and pasting, instead of letting the :D
Don, you can see our posts because you're a moderator.
When we lowly members click "edit" on others posts, we're told to buzz off. :)
That is true on this forum, there are other forums that allow anyone to use the edit button and see the post but you can not submit any changes.
Quoting does almost the same thing though. :)
Sure does. :cool:
George,
Sorry, I didn't know that. I thought this worked like some of the other ones where anyone can view the code.
Don
Originally posted by mkgrady: Can someone tell me how to do this. I can't find anything in the FAQ area.
If you look at the home page of the Forum, you will see something like this at the top:
Mike Holt's Code Forum
My Profile | Member Directory loginregister| Search | FAQ's | Forum Home
The FAQs that you can access from that page have to do with membership in, and use of, the Forum. But look in each topic area, and you will find an FAQ item as the top entry in the category. For example, the topic area that this message is posted in is called "Electrical Contracting and Estimating/Management." Look at the FAQ section in this topic area, and you will see (among other things) instructions for using the "Reply with Quotes" feature.
