Rab flourscent wall pack
la2151
california
HI.. wondering if any one else has had any experience with the rab WP2F84 flourscent wall pack lights? My supplier tells me they are equal to a 150 Watt metal halide light?Other in the field experiences are alwyas the best.. Many thanks. This light has 2- 24 watt flourscent lamps in it.
Although I am not familiar with the product to which you refer, I very much doubt that two flourescent lamps each of 24 watts will produce as much light as a 150 watt metal halide.
Flourescent lighting is often more efficient than metal halide, but only by a relativly small margin.
Flourescent does not have three times the efficiency of metal halide, which is what would be suggested by the above.
It is of course possible that the flourescent luminaire better focusses or directs the light, such that the light level is comparable to metal halide directly below the lamp, or within a certain beam angle.
However the reduced total output would mean less light emitted in other directions, this may or may not matter depending on the application.
Or the supplier may mean that the flourescent light gives the same output as a 150 watt HALOGEN. Metal halide and halogen are very different, but are sometimes confused especialy in imported equipment.
24 watt fluorescent= 1200 lumens x 2= 2400 lumens
150 metal halide= aprox 12000 lumens
although the kelvin rating of a lamp effects how bright the light appears, I dont think a 48 watt fixture is going to be nearly as bright as a 150 metal halide fixture.
