Ohms law
- Sioux Falls,SD
Help! I started installing some led replacement pole heads and one started strobbing. Then proceeded to disconnect another and reconnect original pole that had been disconnected. The strobing effect kept moving to the next pole and to the next as the previous one would stop strobbing and so on. Any ideas what may be happening?
Fyi, original heads had 400watt MH with 120v supply. New led heads have drivers rated for 120 to 277vac
Sent from my SM-G930V using Tapatalk
