electricontr
So what is the difference between a raceway and a sleeve. This is in context with sleeveing a piece of NMB from a new panel and to a circuit emerging from a house. The 08 code does not allow NMB in an exterior raceway due to it now remarkably being declared a wet location. If that is so, why then is NMB allowed in an exterior panel? Nema 3R panels even have drain holes built into the lower rear corners of them. Also, what is the insulation class for the conductors in NMB. Even though they are not clearly marked per NEC, they certainly look and strip like THHN/THWN.
