mister switch
New member
The city of omaha says that a ssu is not ul approved to be mounted on a on a 8787 raco mud ring which is to be used for a single device on a four inch sq box please advise me as what is right john leonovicz
Welcome to my mind. Be afraid; be very afraid.
One of these (Raco 8787) makes a single gang opening.
Ask the AHJ for a code reference.
I would consider the above to be a cover, not a mud ring.
Maybe it is the UL approval the inspector has a problem with. Why would you use the 8787 for a switch on a four square anyway? Why not use a four square RS switch plate to begin with?.......
And that makes a difference how?
Install suffers from "What's on the Truck" syndrome.![]()
One of these (SSU ) is designed for a single gang opening:
I've often heard that the degree of an electrician's skill is directly proportional with his or her ability to make something work with the wrong parts.
I can't decide if I like this notion or not.
I've heard there's at least ten ways to do electrical work:
1. The NEC way.
2. The Mike Holt way.
3. The Tom Henry way.
4. The boss' way.
5. The supervisors' way.
6. The formans' way.
7. The GC/owners' way.
8. The EE's way.
9. The inspectors' way.
10. The "What's on the truck?" way.
11. The forum way
12. The forum way
13. The forum way
14. The forum way...............................................
I cannot see the issue with this install, unless, it is set back more than 1/4 inch from the surface, which may not really be pertinent.
