Dwbrown
New member
- Bethlehem, Pennsylvania, USA
I have a radiant pool installation coming up. Pool is 48" high, will be partially buried, 18" will be exposed above ground. My question is about the equipotential bonding. Above ground pools require #8 around pool 12-18 inches from side, 4-6 inches below sub grade. The only metal available to attach a lug is plate at the bottom of the supports which will be buried @40" below grade. There will also be concrete poured around perimeter of pool. I know rebar must be bonded, but does #8 still need to be run around perimeter of pool attached at 4 places? This will make #8 deeper than 6".
