I am a homeowner. I have recently had an electrical floor heating system installed under a new tile floor. The system came from WarmlyYours http://www.warmlyyours.com This is a 15 watt system, which had been encapsulated in concrete. The contractor made "on-site adjustments" to the plan for the floor grid provided by the manufacturer. His adjustments have placed the wiring under the location where the cabinets are to be installed (despite specific instructions in the manual not to do so).
The contractor (as a remedy) is recommending the wiring under the cabinet locations be excavated, cut to remove it from that location, spliced, reburied in concrete and retiled.
Since cutting the wire and shortening the system will decrease the resistance in the system: the result will be an increase in the wattage of the system. Per a discussion with the manufacturer, they believe the watts may increase to approximately 17+/-.
My question...
Is there a limit to the allowable wattage of such a system that serves as radiant heat for a floor?
Are there other problems with the remedy as proposed by the contracor?
Thanks in advance.
RM
My question...
Thanks in advance.
RM
