I have a ceiling radiant heating system in an apartment building I do repair work in. The building was built in the late sixties or early seventies. In one apartment the living room heat is bad. The square footage is 500 sq. ft. +/-. I get a reading of 28 amps on each leg (240 volt). The feed wire is #12. Thermostat is 2 ft. from panel. The wire leaving thermostat to ceiling is #12. Does anyone know what the amps per square ft. should be or what the cause of this over voltage is. The system has been checked for breaks and there are none. I will not install a 30 amp breaker (per the radiant heat specialist) as the wire is #12 unless someone can tell me different. The two bedrooms are 260 +/- sq.ft. and run +/- 8 amps each.
Thanks
Tom
Thanks
Tom
