Will B
- Fremont, CA
Hi all. We are having a problem related to radio frequencies being generated by a piece of equipment. Some background first:
The equipment is in a large manufacturing facility which uses Substations on the roof (12KV to 480V). The Substations then feed 480v buss duct in the ceiling. Out of the buss ducts are disconnects, then we run conduit to equipment, transformers, etc.
This particular case involves a piece of test equipment (really sensitive) fed from a 120/208V panel (fed from a transformer which is then fed by the buss duct). A new piece of equipment (480v) was installed approximately 1000 feet away powered by the same Substation. After the equipment was powered up and running, we started having problems with the test equipment. Fault codes showed that there were overvoltage spikes which caused the test equipment to shut down.
It took us a week to figure out that the new piece of equipment was the cause and the engineers told us that the equipment does emit RF.
Long story, but my question is, what would you do to protect the test equipment? Filter? Find an independent power source ( I am guessing that the RF is traveling on the conductors)? What do you guys/ gals recommend and why?
Thanks in advance!
Thanks in advance!
