I went on a service call where people were getting shocked when touching the gutters. I put my volt meter between the gutter and a rod I stuck in the ground and found 68 volts to ground. I traced it to a wire that I believe must have gotten a nail in it from the metal lathe they used to but stone on the side of the building. I fished in a new wire but still have 1.5 volts to ground. With the circuit turned off I have .40 volts to ground. The home run comes into a light fixture and splits two ways. One wire feeds the lighting and another wire runs down to the outlets. When I hook up the lighting wire I get just under 1 volt to ground. And then when I hook up the wire for the outlets I get the full 1.5 volts to ground.
Should I be concerned with this 1.5 volts to ground? No where else on the house can I get a voltage reading to ground.( Meter socket, AC units other gutters etc.)
Only the breaker that feeds this area causes the .4 volts to ground go away. So I do not believe some other circuit is causing the problem. And the lighting circuit that cause it to go from .4 volts to just under 1 volt is the brand new wire I ran down to the switch.
Any thoughts would be appreciated. I really do not want this to become 68 volts again down the road.
