Is the inside of a raintight enclosure considered a wet location? Is it acceptable to use FMC inside such an enclosure? Specifically, on a generator installation, is it ok to use "greenfield" to come from the stub-ups in the slab to the breaker enclosure? I believe 348.12(1) says it's ok, if I use THHN/THWN and if the generator enclosure is raintight. But I could be wrong, I've been wrong before.
Thanks.
Thanks.
