pierre
- Westchester County, New York
Bridgeport manufacturing company has now passed the new standard for raintight fittings, and will soon go into production with their new compression fittings. The compression fittings for EMT that will be listed are trade sizes 1/2, 3/4, and 1 inch. Any sizes larger are still not listed.
The fitting is a little different than the ones we are familar with, in that the coupling will have two plastic bushings as well as the 'parts' we are use to. There will be installation instructions and the UL rep told me it will not be difficult to install, just a little different.
You can download the specs from the Bridgeport website if you are interested.
A common question is what to do with the existing fittings you may have, I have been advised to call Bridgeport. GOOD LUCK !!!
Pierre
Pierre
