NEMA MG-2 Safety Standard and Guide for Selection, Installation, and Use of Electric Motors and Generators
4.1 Open Machine (IP00, IC01)
An open machine is one having ventilating openings which permit passage of external cooling air over and around the windings of the machine. The term ?open machine,? when applied in large apparatus without qualification, designates a machine having no restriction to ventilation other than that necessitated by mechanical construction.
4.1.1 Dripproof Machine (IP12, IC01)
A dripproof machine is an open machine in which the ventilating openings are so constructed that successful operation is not interfered with when drops of liquid or solid particles strike or enter the enclosure at any angle from 0 to 15 degrees downward from the vertical.
The machine is protected against solid objects greater than 2 inches.
4.2 Totally Enclosed Machine
A totally enclosed machine is so enclosed as to prevent the free exchange of air between the inside and outside of the case but not sufficiently enclosed to be termed air-tight and in which dust does not enter in sufficient quantity to interfere with satisfactory operation of the machine.
4.2.1 Totally Enclosed Nonventilated Machine (IC410)
A totally enclosed nonventilated machine is a frame-surface cooled totally enclosed machine which is only equipped for cooling by free convection.
4.2.2 Totally Enclosed Fan-Cooled Machine
A totally enclosed fan-cooled machine is a frame-surface cooled totally enclosed machine equipped for self exterior cooling by means of a fan or fans integral with the machine but external to the enclosing parts.
