Rando
New User
- Willow grove pa USA
Trane XE-80 gas furnace will not run powered with a 5500 watt portable generator.
generator is 240/120 volt
My "best guess" is that because it uses an igniter, not a pilot light, any problem with grounding will likely result in the igniter not working and with no igniter, no heater. Igniters are very finicky about grounding...
The XE80 has an adaptive hot surface silicon nitride igniter intended to be safer and more efficient than a pilot light, and the self-diagnostic controls are designed to shut down the unit if a problem arises.
I didn't say it was a spark....
