jetlag
- Eatonton, Georgia
I always thought the neutral on the 4 wire range and dryers only carried the 120 v circuit for the clock and timer. Thats why when it was 3 wire the code let that current go back in the GEC because it was a small current. Im seeing in the code now where the neutral carries the unbalanced load and the conductors are as large as the ungrounded conductors. How can that be ? Are they making the burner switches so they have 240 and 120 supply connected ? The reason Im asking is a lot of people who have a 3 wire rec will buy a 3 prong cord for a new stove. The stove comes with a jumper you can use to bond the neutral and ground. Ok this sends the neutral current into the # 10 EGC that comes in a 6/2 nm cu. I still dont believe the current from the burners goes in the neutral, if it does is this dangerous?
