range calculations
predator
Hey guys
I have 5 {12.4} kw ranges i need to know what the demand load is for these 5 ranges? regards jim Oh and how you arrived at it. :roll:
Re: range calculations
Go to article 220 and do the best you can, then come back with what you came up with and someone will critique your result.
Roger
220.19 over 12kw increase by 5%. 12.4kw so .4x5#of ranges=2kw so 2x5%=1 so where do i go from here the % for 5 ranges is is 20% :confused: :confused:
Jim, just so you know, I'm not trying to give you a hard time.
Note 1 of table 220.19 says the maximum demand will be increased 5% for each additional kilowat of rating or major fraction thereof by which the rating of the individual ranges exceeds 12 KW. With this wording, the .4 being less than a major fraction could be dropped.
With this being the case, column C gives you the KW rating, not a percentage, so you would read across the quantity of 5 ranges line and see 20 KW as the answer.
Roger
ok, then roger what is considered a major fraction? If .4 kilowatts is not a major fraction what would be considered a major fraction 1/2 kilowatt .5. What's the cut off?i don't understand this. So what your saying is disregard the .4 all together. can someone clarify this for me please?regards jim
Jim, "major fraction" is more than .5 (1/2)in any math.
You will see in Chapter 9 note (7) that a specific fraction of .8 is specificaly writen for that application, but for this thread .5 is the cut off.
Maybe someone else will solidify this for you. :D
Roger
Are the values in column A 220.19 actual kw ratings to be applied for the number of apppliances? or the % multiplier?column b less than 3.5 over 12 kw and column c 3.5 to 8.75 over 12kw? :p
Annex D Examples p70.667
Ranges
Annex D p70.672
Example D6 Max demand for range loads.
thanks boys
:D ;) :cool:
