Range connection problem solved!
jrannis
What do you do when you want that range really tight to the wall and dont want to loose space to that pesky cord cap?
Just push it through a hole in the back of the 6x6 junction box on the outside of the wall.
Panel schedule was written in French for some reason??
For those device tapers out there.............
attachment.php
Is it me or does that range recept have sort of a bizzare yoke?
Not bizzare, French. ;)
When I bought my house I found a 50a range recep parallel fed w/ a #10 and a #12 romex set... Maybe this guy moved to Michigan. At least in my case, he put it in the room below the kitchen. :cool:
Sorry no pictures,
Doug S.
Whats the 12awg for?
That would be for the window shaker AC installed in the block wall.
I was there to check out the insta-hot installed in place of an undercounter tank unit. 40amp pullout feeding the interior panel. the 56amp draw on the panel kept blowing fuses. Could only take a quick shower with the lights off.
