Re: Range outlet
My inspector told me that when I connect my new oven to the old 3 wire circuit that, according to 250-130, I should use a 4 wire plug to a new 4 prong receptacle and run the 4 wire conductors back to a J-Box for splicing to the old, original branch circuit. At the box I can pigtail the ground to the box and then, this is the crucial part, run a single conductor ground to within 5 feet of where the cold water pipe enters the building and bond at that point. (No mention of cutting jumpers)
I'd asked about grounding at the subpanel but that was a definite no-no since it needed to be grounded at the origination of the branch circuit, or, bonded as described above.
Does this sound like safe advice? That's my primary concern.
D-
[ November 20, 2004, 01:51 AM: Message edited by: DjZee ]
