Stevenfyeager
- United States, Indiana
- electrical contractor
A range was shocking people. I found 119 volts from some screws in the oven to ground! It was improperly wired, a 3 wire with no bonding strap. Also the terminal block was broken and had been held together with tape. One of the hot lugs was loose and may have been touching the junction cover on the stove, but no sign of any heat, black, etc. is this because the missing bonding strap means it was not grounding and therefore no arc whatsoever? The only grounding would be a person touching the stove ? Thank you
