bbartmasse r
- Washington State
Hello all,
We are installing a new ground mount array into an existing grid tied/battery based system.
The conduit from the array travels about 50 feet before it enters the basement of the home, where it then travels another maybe 100 feet to the charge controller.
My question has to do with Rapid Shutdown. I have read that it does not apply to to underground runs, which makes perfect sense. So where it would start to apply is when it comes into the basement (I think the code allows for up to five feet unprotected in the building).
Are there any specifications on what the "initiator" is supposed to look like and where it should be placed?
can I not have a standard combiner box with breakers that are the "rapid shutdown" in this case. The box would be located on the outside wall of the building.
We have used the fancy gizmos from Midnight when our arrays are on roofs but it seems in this case we would not need one at all?
thoughts?
thanks
thoughts?
thanks
