RE: 334.80
ashtrak
Maryland
RE: 334.80
I am curious to know if the inspectors in different areas are all enforceing 334.80, which says that NM ampacity will be in accordance with the 60 degree rating.I've seen #6 NM CU used for 60 amp hot tubs that passed inspection, and I've see it fail. In both instances 60 amp breakers were installed. Thanks
Re: RE: 334.80
maybe you should make it a poll instead of a question..
enforced here
[ November 30, 2005, 06:48 AM: Message edited by: augie47 ]
