Hi,
I have a project where a client would like to reuse existing 12KV switchgear on the secondary side of a new transformer operating at 4160V. At first I was thinking this should be fine since we are going down in voltage, and everything would just be oversized in regards to voltage. But now I"m have second thoughts.
Thanks.
- There is a 150E fuse in the gear, but it is rated for 12KV obviously. So will I need to change this to 4160V?
- Won't the size of the fuse change so that it may no longer fit within the disconnect?
- Along with the meter PT and Ct's, won't there be other auxiliary components that need to be altered or swapped out?
- Would a testing agency be able to make all these changes?
- Would a testing agency be able to re-certify and change the nameplate, or do I have to contact the original manufacturer?
Thanks.
